Go Back   Forum Index > Shared Forums > Ask All Sailors
Ask All Sailors This forum is for owners of ALL sailboats. It's shared by Hunter, Catalina, Beneteau, MacGregor, O'Day, and other owners. For questions and comments specific to your brand of boat, please use the appropriate forum.
Reply
Thread Tools Search this Thread
Old 11-03-2009, 01:34 pm   #1  (permalink
stx203
O'Day 25
Chesapeake
stx203 hasn't generated any comments yet, may be new around here
Vire 7 gas/oil mix
I've just purchased a 77 O'Day 25 tall rig with the Vire 7 gas engine...even came with original manuals and documentation that it was rebuilt in 98. I've searched the boards for info and have found a lot but I'm curious about your opinion on oil mixture. The original manual suggests 32:1 for breaking in a new engine then shift to 50:1 There is a note in the log from a previous owner mentioning 4oz/gal....unfortunately the most recent owner has passed away and the seller(a relative) has no idea what was used last. What have you found to be the best mix for your engine? Thanks for your advice.
stx203 is offline
Old 11-03-2009, 07:48 pm   #2  (permalink
Donalex
Hunter 376
Warsash, England
Donalex's Avatar
Donalex hasn't generated any comments yet, may be new around here
Mixture and a Tip
  Top
I owned a Vire 7 for seven years and always used 50:1 mixture using regular self mixing 2 cycle outboard motor oil or that used in motorcycles and scooters. If yours has not yet been run in after rebuild then 32:1 would be a kindness.
Tip:- The manual advises to set the mixture by closing the throttle against the stop screw and adjusting the idle mixture screw for maximum rpm and then backing off the throttle stop and repeating the process until it idles nicely.
Once the idle is set then one engages forward gear, goes to full throttle and adjusts the main jet mixture screw for maximum rpm.
I found that when I went back to idle, normally just as I was approaching the dock, and then engaged reverse and opened the throttle again to stop the boat, the engine often used to cut out and refuse to start again. Hair raising and very embarrassing whilst heading down a blind alley!
I diagnosed this as being too lean at idle to allow the engine to accelerate under load. The remedy is to unscrew the idle mixture screw one full turn and adjust the throttle stop to maintain best idle speed. This means it runs slightly rich at idle but this does no harm anyway.
Donalex is offline
Old 11-04-2009, 08:18 pm   #3  (permalink
jackhartjr
Oday 22
Hickory, NC
jackhartjr hasn't generated any comments yet, may be new around here
Re: Vire 7 gas/oil mix
  Top
Try this site;
http://gofree.indigo.ie/~vire7/home.htm
Jack
jackhartjr is offline
Old 11-05-2009, 06:38 am   #4  (permalink
stx203
O'Day 25
Chesapeake
Re: Mixture and a Tip
  Top
Thanks for the info....very helpful. In your locale what did you do to winterize the VIRE? And when winterizing, if done, did you drain the fuel tank, keep it full, or neither?
stx203 is offline
Old 11-06-2009, 08:04 am   #5  (permalink
Donalex
Hunter 376
Warsash, England
Donalex's Avatar
  Top
Hi STX,
In our locality I lifted out for the winter and did nothing to winterize the engine. I don't recall if there was a drain cock on the engine but, if there was, I would simply have opened it.
BTW winters are mild in Southern England. Only rarely do we see -5°C (41°F) and then only briefly overnight.
Now, with a Hunter + Yanmar, I remain afloat all winter and again do no winterization of anything
Donalex is offline
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Visit our store at
S2Owners.com...
30% off custom embroidered sportswear
Polos, jackets, sweatshirts... mens, womens, childrens... all with NO minimum, NO setup fees, super-saver prices!
15% off unbreakable engraved drinkware SALE
Bulletproof Lexan drinkware engraved with your boat name. Wine, champagne, beer, tumblers, pitchers, more.
Solar/wind charger
Charge cell phone, MP3 players, cameras, more, without AC or DC power!
15% off butcherblock stove top cutting board
Our butcher block stove top cover is a true work of art! Turn your stove top into useable counter.
Halyard retriever
Don\'t go up the mast! Also works as a handy grapling hook. Sturdy stainless construction.
